John245
May 06, 2021Tutor
Shares Gone 2120v2
Marc_V In the 4th comment of this post it was mentioned that a script is available to solve the issues of shares that are gone. https://community.netgear.com/t5/New-ReadyNAS-Users-General/Share...
- May 06, 2021
John245 wrote:
root@TEAPHOMENAS01:~# root@readynasos:#/ curl -s https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh/raw/master/share_lun_ui_fix.sh | bash
-bash: root@readynasos:#/: No such file or directoryYou're supposed to just enter this bit:
The root@readynasos:#/ preamble was just representative of the normal Linux CLI prompt.
Did you use df to check the fullness of the root partition? You really should do that before running the script.
Also, as the web page notes, you need to be running 6.10.0 or later firmware.
May 06, 2021Guru - Experienced User
What firmware are you running?
John245 wrote:
. How can I get my shares visible?
One option is to used paid technical support via my.netgear.com. The mods ( JohnCM_S and Marc_V ) can facilitate that. Ask if you can get per-incident support.
If you want to pursue this yourself:
- It'd be good to first check if the root partition is full with df, as that can damage configuration files. The root partition is only 4 GB. Normally it's about 25% full.
- If you can download the full log zip file from the web ui Logs tab, then you could also look in there to get more information on what went wrong.
- There is a script you could try here: https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh
John245
May 06, 2021Tutor
Thanks for the suggestions. But acces to root is denied. And running the script will tell that the filename directory is missing.
John
