bruceread
Aug 16, 2015Aspirant
Simple Connection Question
I have a new ReadyNAS RN10200 and have a simple connection question. My computers connect to the internet through a mobile hotspot on my cell phone, so I have no physical router to which to connect ...
vandermerwe
Aug 16, 2015Master
The readynas must connect via Ethernet to something.
Does the mobile hotspot (gateway) have an IP address as on a LAN? and are the computers connecting to it via a wireless LAN that the mobile hotspot creates?
If this is the case I think you will need to connect the nas to an access point of some sort then incorporate the AP into the LAN.
You could, as I think you have tried, connect direct to a PC, This will limit the functionality of the nas though as it will not be a LAN device and won't have an Internet connection.
Aug 16, 2015Guru - Experienced User
You can get a WiFi extender (or use a WiFi router in bridge mode). That will let you connect the NAS via ethernet.
- brucereadAug 20, 2015Aspirant
Thanks! And if I connect to a bridge via ethernet, will that disable the computer's wifi connection to the mobile hotspot? I have a bridge and seems that I tried that but then had a problem with the wifi.
Bruce
- StephenBAug 21, 2015Guru - Experienced User
Bruce
Your hotspot should see the extender as another client. So it should not affect your computer's wifi connection. There may be an issue with the specific bridge/hot spot combination you are using though.
Were you getting internet from the ethernet connection?
