bruceread
Aug 16, 2015Aspirant
Simple Connection Question
I have a new ReadyNAS RN10200 and have a simple connection question. My computers connect to the internet through a mobile hotspot on my cell phone, so I have no physical router to which to connect ...
Aug 16, 2015Guru - Experienced User
You can get a WiFi extender (or use a WiFi router in bridge mode). That will let you connect the NAS via ethernet.
bruceread
Aug 20, 2015Aspirant
Thanks! And if I connect to a bridge via ethernet, will that disable the computer's wifi connection to the mobile hotspot? I have a bridge and seems that I tried that but then had a problem with the wifi.
Bruce
- StephenBAug 21, 2015Guru - Experienced User
Bruce
Your hotspot should see the extender as another client. So it should not affect your computer's wifi connection. There may be an issue with the specific bridge/hot spot combination you are using though.
Were you getting internet from the ethernet connection?
