jmaxlow
May 05, 2019Aspirant
Slow read speed vs. right speed RN516 and RN214
I'm experiencing much slower read speed than write speed on two different ReadyNas units - RN516 and RN214. Both are hooked to an HP Procurve gigabit switch with cat5e cables. The PC is hooked to the same switch with a cat5e cable. SMB is the protocol. Anti-virus is off on the two NAS units and off on the PC. Below are the results from NAS Performance Tester, where H: is the 516 and K is the 214.
Any ideas on what could be causing this?
Running a 2000MB file write on H: 3 times...
Iteration 1: 57.15 MB/sec
Iteration 2: 51.54 MB/sec
Iteration 3: 75.82 MB/sec
Average (W): 61.50 MB/sec
Running a 2000MB file read on H: 3 times...
Iteration 1: 26.56 MB/sec
Iteration 2: 22.14 MB/sec
Iteration 3: 28.15 MB/sec
Average (R): 25.62 MB/sec
Running warmup...
Running a 2000MB file write on K: 3 times...
Iteration 1: 43.47 MB/sec
Iteration 2: 65.40 MB/sec
Iteration 3: 60.45 MB/sec
Average (W): 56.44 MB/sec
Running a 2000MB file read on K: 3 times...
Iteration 1: 32.10 MB/sec
Iteration 2: 31.96 MB/sec
Iteration 3: 31.73 MB/sec
Average (R): 31.93 MB/sec
How long have you been experiencing this problem?
Have you tried a different PC?
I suggest checking the network stats on the two NAS - download the log zip file and look in network_settings.log
