Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ReadyNAS firmware then did a factory reset. Disk 4 took most of an evening to resync, but finally finished. So far it's been running fine as I've been copying data off my old NV+ on to the new Ultra 4.
The Ultra 4 is sitting in the bottom of my gun safe, so low heat is rather important to me and I thought a 5400 would be a better bet. So far I haven't seen any Temp1 above 140f or so and the HD's are usually at or under 100f, never seen one above 108f. I was worrried that the enclosed fireproof safe would end up retaining too much heat, but it's been 3 days now with no problems. When I have the safe open the drives are very quiet, not surprisingly closed you can't hear a thing at all.
Will try and post later when I see how they hold up.
- WrackyAspirantHey everyone,
I just installed 2 of these drives in my ReadyNAS duo myself.
I updated the firmware to 4.1.7-T60 and started a Factory Default from FrontView, after which I used RAIDar to set the device to Raid 1 mode.
Everything seems to work fine, it's syncing now at 90 to 100MB/sec ... however Hingy here said the partition logs for him now show "disks are aligned for the 4K sectors"
I've looked in partition.log and can't find anything that would suggest 4K sectors :-/
The Log looks like this now:
Disk /dev/md0 doesn't contain a valid partition table
Disk /dev/md1 doesn't contain a valid partition table
Disk /dev/md2 doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
Device Boot Start End Blocks Id System
/dev/hdc1 32 4096031 2048000 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary.
/dev/hdc2 4096032 5144607 524288 fd Linux raid autodetect
Partition 2 does not end on cylinder boundary.
/dev/hdc3 5144608 3907012815 1950934104 fd Linux raid autodetect
Disk /dev/hde: 2000.3 GB, 2000398934016 bytes
/dev/hde1 32 4096031 2048000 fd Linux raid autodetect
/dev/hde2 4096032 5144607 524288 fd Linux raid autodetect
/dev/hde3 5144608 3907012815 1950934104 fd Linux raid autodetect
Note: sector size is 1024 (not 512)
Disk /dev/md0: 2097 MB, 2097086464 bytes
2 heads, 4 sectors/track, 255992 cylinders, total 2047936 sectors
Units = sectors of 1 * 1024 = 1024 bytes
Disk /dev/md1: 536 MB, 536805376 bytes
2 heads, 4 sectors/track, 65528 cylinders, total 524224 sectors
Disk /dev/md2: 1997.7 GB, 1997756432384 bytes
2 heads, 4 sectors/track, 243866752 cylinders, total 1950934016 sectors
Raidiator_version.log says. RAIDiator!!version=4.1.7-T60,time=1287008617
Is this OK ?
Thanks! - mdgm-ntgrNETGEAR Employee Retired
That's fine. You can see the start numbers are divisible by 8 and the first one is 32, which is what you expect to see with 4k sector alignment on Sparc ReadyNAS. Remember 512 bytes * 8 = 4k - goondogAspirantmdgm
if one wanted to add another one of these 4k drives in the future can they be added without a factory default if the previous drives have already been aligned with a factory default? - WrackyAspirantThanks very much! Sync is done now, and it looks like everything's working just fine :)
I think that should work. - goondogAspirantthanks mdgm.
i now have running 1 hitachi 2TB off the HCL and 2XSamsung F4s with 3.6T total
I plan on adding another samsung 2TB next week for a total of about 5.4TB
i factory reset the first three drives and everything looks ok but wanted to make sure i got 4K properly set up.
below is my partition log:
thanks again for all the help on the forums!
Disk /dev/hdg doesn't contain a valid partition table
Disk /dev/hdc: 2000.3 GB, 2000388448256 bytes
255 heads, 63 sectors/track, 243200 cylinders, total 3907008688 sectors
/dev/hdc1 32 4096031 2048000 83 Linux
/dev/hdc2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hdc3 4608032 3906992335 1951192152 5 Extended
/dev/hdc5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hde: 2000.3 GB, 2000388448256 bytes
/dev/hde1 32 4096031 2048000 83 Linux
/dev/hde2 4096032 4608031 256000 82 Linux swap / Solaris
/dev/hde3 4608032 3906992335 1951192152 5 Extended
/dev/hde5 4608040 3906992335 1951192148 8e Linux LVM
Disk /dev/hdg: 2000.3 GB, 2000388448256 bytes
Disk identifier: 0x00000000 - WrackyAspirantI basicly asked the same question yesterday, and since this was mdgm's answer:
"You can see the start numbers are divisible by 8 and the first one is 32, which is what you expect to see with 4k sector alignment on Sparc ReadyNAS. Remember 512 bytes * 8 = 4k"
I think you're fine :) - goondogAspirantWracky
thanks i did see that after reading the post closer.
thanks again for the confirmation- always good to have another set of eyes! - bdomanAspirantHeads up - the Samsungs are on sale at Newegg for $60!
2TB SAMSUNG Spinpoint F4 3.5" SATA 3.0Gb/s Internal Hard Drive $59.99 + FS
With Code EMCZYNW48
http://www.newegg.com/Product/Pro...6822152245
http://slickdeals.net/forums/showthread.php?t=2351067 - ctc2AspirantI currently have 3 HD2030WI drives in an NVX Pioneer with firmware 4.2.15 and want to add a 4th drive. Does anyone know if I add a new HD2040UI, would I have a problem with sector alignment since this is the first 4k drive added to my volume? Or would I still have to do a factory default?
Thanks.
