Fallon
Oct 15, 2010Aspirant
Spinpoint F4 HD204UI 2TB 5400 RPM working good so far
There was a recent deal at NewEgg on the SAMSUNG Spinpoint F4 HD204UI 2TB 5400 RPM 32MB drives, so I decided to risk it as opposed to the other WD & Seagate 2tb drives. I installed them, upgraded the ReadyNAS firmware then did a factory reset. Disk 4 took most of an evening to resync, but finally finished. So far it's been running fine as I've been copying data off my old NV+ on to the new Ultra 4.
The Ultra 4 is sitting in the bottom of my gun safe, so low heat is rather important to me and I thought a 5400 would be a better bet. So far I haven't seen any Temp1 above 140f or so and the HD's are usually at or under 100f, never seen one above 108f. I was worrried that the enclosed fireproof safe would end up retaining too much heat, but it's been 3 days now with no problems. When I have the safe open the drives are very quiet, not surprisingly closed you can't hear a thing at all.
Will try and post later when I see how they hold up.
- lazerharpAspirant
shadowz wrote: Hi,
I'm having same issue as marcelser, but with X-Raid. playing any video files from the NV unit with the samsung drives will lag, stutter, or just freeze. I have another unit that has the wdc10eacs drives which does not have such issues with the same file. I've went over the config and both units have identical performance options. I'm about to take them out and return it.
Anyone having this problem with DUO? I mainly use the DUO for media streaming so it would be a disaster if this would be the case.
/L - Mutley1AspirantI'm using x-raid on my Duo and no problems streaming media for me, via the Lan or Wifi.
- philbert1AspirantHi Everyone -
I'm a long-time reader, first time poster. I just purchased two new Samsung Spinpoint F4 HD204UI's for my ReadyNAS Duo. Like many other Mac users here I've been trying to figure out the best way to upgrade the firmware on the drives. Luckily one of my Macs is a first generation Mac Pro from 2006. It's easy to add and remove SATA drives to the Mac Pro's, so all I had to do was figure out if the Pro was capable of booting into DOS and running the F4EG.EXE firmware update utility from Samsung. Luckily it was! Here's what I did:
[DISCLAIMER: Proceed at your own risk. I strongly suggest reading through ALL instructions carefully before attempting this. If you're uncomfortable doing anything on the list, then don't! It doesn't make you any less of a computer nerd. And it goes without saying: I'm in no way responsible for any loss of data or hardware damage you might suffer.]
Overview:
What I did was essentially create a DOS boot CD using Windows 7 and VMWare Fusion. I burned it to a blank CD via the Mac's Disk Utility application. I then shut down, pulled all my SATA drives from my Mac Pro, and put one of the new Spinpoint drives in Bay 1. I booted my Mac using the new DOS boot CD and ran the F4EG utility to update the firmware. I then shut down and did the same thing for my second new Spinpoint. Finally, I put all the original drives back into my Mac Pro and was done.
Hardware and Software Used:
First Generation Mac Pro from 2006 (MacPro1,1) with EFI firmware 1.7f10
Snow Leopard 10.6.4
VMWare Fusion 3.1.2 w/ Windows 7 Pro installed (Parallels or Boot Camp would probably work also). WinZip installed (but I don't think it's necessary).
1 blank writable CD
Instructions:
[Steps 1 thru 11 must be done using Windows]
1. Start up Windows 7 using VMWare and launch any web browser.
2. Download the Samsung F4 Spinpoint patch software from http://www.samsung.com/global/business/hdd/faqView.do?b2b_bbs_msg_id=386
3. Unzip the archive and locate the F4EG.EXE program.
4. Go to http://www.hiren.info/pages/bootablecd
5. Feel free to skim through Hiren's site, but don't spend a lot of time worrying about it. There's some info about modifying Autoexec.bat and Config.sys files, but none of that will be necessary:-)
6. Download Hiren's bootcd.zip archive: http://www.hiren.info/download/freeware-tools/bootcd.zip
7. Unzip the contents of bootcd.zip to a new directory.
8. In the new directory, you should see several subdirectories (CD, Floppy, Tools) as well as Build-ISO and a readme file.
9. Copy the F4EG.EXE utility you downloaded from Samsung to the Floppy folder.
10. Double-click the Build-ISO icon. This will run a simple batch file and create a new file: BootCD.iso
11. At this point you'll need to copy BootCD.iso to a location on your hard drive that you can access via the Mac's Finder. For VMWare Fusion, typically that's a special "shared" folder set up to trade files back and forth between the Windows and Mac environments.
12. Locate a blank CD or DVD. Launch the Mac's Disk Utility program (located in Applications\Utilities). Use it to burn the BootCD.iso disk image to your blank CD or DVD.
13. If Disk Utility ejects the CD/DVD after the burn, put it back in your Mac.
14. At this point, it's time to start the process of upgrading the Spinpoint drives. Shut down your Mac (making sure your newly burned CD or DVD is still inside). IMPORTANT: Unplug your computer.
15. Disconnect all external USB and FireWire drives.
16. Open the Mac Pro's case. Remove all internal SATA drives (just slide out the sleds). If you've never swapped an internal drive on your Mac Pro before, you may want to refer to your Mac Pro's manual as a reference. Note that a little extra force may be necessary for any internal drive that's never been removed from your Mac Pro.
[The next few steps will need to be repeated for each Spinpoint drives you want to patch]
17. Attach your Spinpoint drive to one of the hard drive "sleds" and insert it into Bay 1 (the bay closest to the front of the Mac Pro). The two most important things to know are:
a) you won't need any cables
b) be careful when sliding the SATA drive into the bay (you don't want to damage the connectors inside your Mac or on your drives)
18. At this point, you should have:
a) a single Spinpoint SATA drive in Bay 1
b) a bootable CD or DVD in your DVD drive
c) no other hard drives attached to your Mac Pro in any way
19. Plug the power cord back into the Mac Pro and wait about 5 seconds.
20. While holding down the Option key on your Mac's keyboard, press the front power button.
21. Continue to hold down the Option key. After a few moments, you should see a gray screen with a single large DVD icon and the word "Windows" underneath. It can take up to 30 seconds for this to appear so be patient. If the large DVD icon never appears, then you may have created the BootCD.iso file incorrectly, or you may have burned the CD or DVD incorrectly.
22. Release the Option key. Click the Arrow icon below the word "Windows". This tells the Mac to boot from the optical drive.
23. You should see your monitor flash several times, and eventually see a blinking underscore character in the top left of your screen. Be patient. You may have to stare at that blinking underscore for several minutes.
24. The Microsoft Windows Startup Menu should appear. Now it's going to get fun!
25. Use your keyboard to select item 1 (Dos) and press Return.
26. The boot CD will load a few drivers. This should only take a few moments.
27. You should then get dropped to a old-school A:\> Dos prompt. Bet you never expected to see that on your Mac!
28. Type DIR and press Return. Make sure the Samsung F4EG.EXE program is listed. If it's not, you may have created your boot CD incorrectly.
29. Finally, it's time to upgrade the firmware on your drive. Type F4EG.EXE and press Return. This will start the firmware update process. The update should take less than a minute.
30. Once you see the message "Download completed successfully" along with a serial number, you're done. The drive has been successfully patched!
31. Shut off your Mac Pro by holding down the front power button for a few seconds.
32. Unplug the power from your Mac Pro.
33. Remove the Samsung Spinpoint hard drive. If you have multiple Spinpoints that need to be patched, then repeat Steps 17 through 33.
34. Once all Spinpoints have been patched, return your Mac Pro to its original state. Put the original Mac hard drives back in their proper bays, and re-connect any external USB and FireWire drives.
35. Boot up your Mac to make sure everything is okay.
You're done! Your Samsung Spinpoint drive(s) should now be ready for your ReadyNAS Duo!
It took me several hours of research, then several more hours of trial and error to get this to work. I just hope someone else out there finds the information helpful:-) Good luck!
- phil - lazerharpAspirantHi,
I just bought two HD204UI for my DUO. How do I know if I have to upgrade firmware and why?
Best regards,
L - philbert1AspirantHi lazerharp -
From what I've gathered reading these boards, the firmware version reported by the Spinpoint F4 drive is the same before and after the update is applied (ie, there's no way to know if your new drive already has the patch). So unfortunately I think the consensus around here is "since there's no way to tell if the firmware needs upgrading, do the patch anyway just to be safe".
Hope that helps :)
- phil
P.S. I wanted to mention that my ReadyNAS Duo with two Spinpoint F4's has been operating smoothly for a week now. Thanks to everyone on this board for their insight and information. - TechZ1Aspirant10 pages and I'm totally lost!
My current ReadyNAS is almost full and planning to get either an NV4+ or an Ultra4, but deciding what 2TB drive is getting to be a nightmare. There are just too many revisions of the F4 Spinpoint and the WD EARS/WD EADS drives! - Jaja1AspirantNV+ with 2x HD204UI F4EG SA2
serialnumber s2h7jd 2b117955 and further...
raidiator 4.1.7
took over 14 hours to sync, from clean install, so be patient
working.
greetz - neoberlinAspirantHi everyone,
I got my ReadyNas Ultra 4 Plus two weeks ago along with two Samsung F4.
Did the firmware update as shown in this threat (thanks alot for this!).
Happy to tell you, everything is smooth so far. Partition.log shows:
Device Boot Start End Blocks Id System
/dev/sda1 64 8388671 4194304 fd Linux raid autodetect
Partition 1 does not end on cylinder boundary.
/dev/sda2 8388672 9437247 524288 fd Linux raid autodetect
Partition 2 does not end on cylinder boundary.
/dev/sda4 9437248 3907024064 1948793408+ 5 Extended
/dev/sda5 9437256 3907024064 1948793404+ fd Linux raid autodetect
Disk /dev/sdb: 2000.3 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders, total 3907029168 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x00000000
/dev/sdb1 64 8388671 4194304 fd Linux raid autodetect
/dev/sdb2 8388672 9437247 524288 fd Linux raid autodetect
/dev/sdb4 9437248 3907024064 1948793408+ 5 Extended
/dev/sdb5 9437256 3907024064 1948793404+ fd Linux raid autodetect]
Mine has a Start count of 64 (most of the partition.log in this threat have 32 as Start count), but I figure, this should be fine.
So fare anything works very smooth. Fan is very silent, hard drives are around 29/32C (my NVX with two Barracuda Seagate which are shipped with the ReadyNasNVX are usually on 40/42C, so the fan is running much louder).
Performance is very fast to stream and copy. But rsync on my LAN (600GB) took as well one day.....
So far, so good...I'm happy! - Just added two of these to my Duo.
I upgraded the firmware via the links posted here somewhere. The _jp FW wouldn't work for me at all, however the standard UK/US FW worked and I verified it twice (after 2 complete shutdowns) and ESTool reported the FW was being being shown as the new version.
Both are currently being factory reset in the Duo. Fingers crossed all goes well! - I'm confident it will! ;) - TBone1AspirantTwo simple questions:
1.) What is the performance like with the Spinpoint F4 drives using the NV+ or Ultra 4?
2.) Is Netgear ever going to put these on the compatibility list?
Thanks!
