gixxer-27
Jan 21, 2022Initiate
Stora died and want to recover data
Hi All, I have a Netgear Stora (not sure of model number) that died and will no longer power on. Fan turns on but that is all. I managed to get my hands on a used Stora that is working and wante...
Marc_V
Jan 21, 2022NETGEAR Employee Retired
Welcome to the Community!
After April 01, 2020 The Stora cloud service ended so transferring the drives to a working Stora will not work since you need to access mystora.com to setup and access data. You may have to recover the data using another option, here is one option.I found a few post getting success doing this procedure but you may need a PC running Ubuntu.
Another option is to use 3rd party applications like R-Studio. Users who perform recovery might be able to chime in and help.
HTH
Jan 21, 2022Guru - Experienced User
Unfortunately, R-Studio doesn't support XFS.
ReclaiMe does, but is considerably more expensive.
- SandsharkJan 22, 2022Sensei
StephenB wrote:
Marc_V wrote:Another option is to use 3rd party applications like R-Studio.
Power ISO also claims to do so, but I've not used it for that. I suspect it's capability is limited in the trial version. https://www.poweriso.com/tutorials/access-xfs-partitions-from-windows.htm .
