wideef
Oct 07, 2017Aspirant
suggestions for upgrading memory on the RNDP4000 (pro 4)
hi, due to our pro 4 locking up on oS6 a suggestion was made to try upgrading the memory. we have seen the post about 4gb of gskill working but has anybody else upgraded their memory on a Pro 4 a...
- Nov 26, 2017
so after much testing and access checks we wanted to share with you that our issue has now been solved!
we upgraded the pro 4 with one stick of Crucial CT25664AC800 2GB DDR2-800 SODIMM RAM as per the suggestion of StephenB and, together with the shift to OS 6.8.1, it's all working perfectly again! the unit also feels snappier when accessing pages, directories and even frontview so we're over the moon to have this working again.
we'd just like to say thank you very much for everybody that has chimed in and offered their support in trying to fix this and no worries about the mix up shandshark; very grateful to have had your suggestion
wideef
Oct 16, 2017Aspirant
should have popped the lid before buying as hynix 2GB HMT325S6BFR8C-H9 arrived but it's ddr3 and our RN is ddr2 which means it doesn't fit. maybe we've/you've got a different board to the one we have?
so the search goes on; anybody have any other ddr2 sodimm recommendations for RNDP400 (Pro 4) please?
Sandshark
Oct 16, 2017Sensei
I upgraded the Pro4 for somebody else and looked up what I bought. Now I'm thinking I may have made a mstake and that's the memory for the Pro2. But why the Pro2 would use DDR3 and the Pro4, expected to be a more capable system, would use DDR3 is beyond me. My appologies if I steared you in the wrong direction.
- wideefNov 26, 2017Aspirant
