fankalfr
Apr 28, 2016Aspirant
Time Problem
Hey, i've got a ReadyNAS 516. It works like a charme... Except one annoying problem First of all i Use Windows 7 64 Bit and have mapped the shared folder from the NAS as drive X:\ This is wh...
Apr 28, 2016Guru - Experienced User
How far off is the time you are seeing?
Also, can you confirm that you are using the right time zone on both the NAS and the PC?
- JennCApr 28, 2016NETGEAR Employee Retired
Hello fankalfr,
Welcome to the community!
Are the date and time settings of both ReadyNAS and Windows machine synchronized? May we also ask for the FW version of the ReadyNAS?
- fankalfrApr 29, 2016Aspirant
Hello JennC,
Date and Time of PC and ReadyNAS are both the same. Also Timezone is the same.
Firmware of the ReadyNAS = 6.2.2
Thanks!
Regards
Alfred
- StephenBApr 29, 2016Guru - Experienced User
It still sounds like a timezone problem of some sort. The NAS is set to GMT+1 (Vienna)??? Are you using Netgear's time servers?
Exactly 9 hours ahead.
I made a new Textdocument, Windows Explorer is showing 22:14
The time on the ReadyNAS and PC is 13:14
So its exactly 9 hours ahead
