JezZedex204
Jan 01, 2016Aspirant
Transfer speed on rn204
Hi there. I am new to this NAS environment and need to find out a thing or two to find out if things are good or if there could be an issue. I am copying data (photos, videos and cad drawings, et...
- Jan 04, 2016
Update!
I bought a switch and connected it to the set up. Now the transfer speeds are more in line with what I would have expected. Copying a folder of mixed info (pdf's, photos, docs, xls s/sheets) and going over at 50MB/sec.
Much better. Just to says thanks to StephenB and Sandshark for all the help figuring this out. If this speed is what I should be getting great. If it could be higher I would be interested to hear further ideas.
:manhappy:
JezZedex204
Jan 04, 2016Aspirant
Update!
:manhappy:
Kardano
Jan 04, 2016Luminary
If i may ask.... (If you are running on FW 6.4.1) Is antivirus on your RN204 enabled or disabled?
If antivirus is enabled, try to disable IT: in settings -> services - antivirus:
after disabling check speed again.
These are my results with my RN204 (4x WDRED 3TB in RAID5) to my PC (i7, 16GB RAM, Windows7 Pro) with NAS performace tester 1.7 and 1000MB file:
(Antivirus on NAS is disabled, checksum enabled, AV SW in PC is running)
NAS performance tester 1.7 http://www.808.dk/?nastester
Running warmup...
Running a 1000MB file write on \\pmnas02\backup 5 times...
Iteration 1: 84,63 MB/sec
Iteration 2: 87,55 MB/sec
Iteration 3: 87,86 MB/sec
Iteration 4: 86,82 MB/sec
Iteration 5: 86,65 MB/sec
Average (W): 86,70 MB/sec
Running a 1000MB file read on \\pmnas02\backup 5 times...
Iteration 1: 109,16 MB/sec
Iteration 2: 105,56 MB/sec
Iteration 3: 101,59 MB/sec
Iteration 4: 105,39 MB/sec
Iteration 5: 110,11 MB/sec
Average (R): 106,36 MB/sec
