crown
Jun 12, 2020Aspirant
Transfer to new NAS (files and settings)
I have a readynas nv+ which I know should be upgraded. Howver, I keep putting off upgrading to a newer unit due to the fear of having to start from scratch. Does anyone have a proceudre for movin...
bcrown
Thanks for the confirmation. I feel like a visit to Synology may be the solution as I do not need to go through this exercise the next time as well.
Jun 13, 2020Guru - Experienced User
Netgear has supported direct migration in all OS-6 systems since its introduction in 2013. That includes migration from the arm platforms to the x86 ones. So I don't think this is something you'd run into again.
Though personally I haven't found setting up from scratch to take very long. The RAID build is the longest step, and transferring settings doesn't make that go any faster.
- bcrownJun 13, 2020Aspirant
Thank you for the follow up information.
