Raybot
May 13, 2012Tutor
Truecrypt 7.1a on NV+ v2 (ARM) howto
EDIT: Warning, looks like there's a bit of a mistake in these instructions and wxWidgets is still required in part for the command line version - turns out I had some remnants of wxWidgets source on m...
christophd
Aug 18, 2012Aspirant
Hi,
turns out there is a ready-made Debian package for wxWidgets which allows compilation of TrueCrypt. Here's how you get it going:
And then do the "make NOGUI=1" in the TrueCrypt source directory. Voila! Worked like a charm for me.
apt-get install wx2.8-headers libwxbase-2.8
