JarnoG
Aug 22, 2020Guide
Ultra 4 doesn't boot anymore after restart
My ReadyNAS Ultra 4 has been running OS 6 happily for a long time now. Recently I restarted it using Frontview. It powered down as usual, but after that it didn't boot anymore. When I turn it on, the...
JarnoG
Aug 23, 2020Guide
Thanks for the quick reply.
It doesn't matter if I have my usual drives installed, a single spare drive or no drives at all. In all cases the backup-button-light, the powerbutton and HDD4-light are on. In none of the cases, the NAS is recognised by RAIDar.
JarnoG
Aug 23, 2020Guide
Also, the LED display shows an _ with a blinking block over it, no matter whether or not there are any disks in the NAS.
- SandsharkAug 23, 2020Sensei
That does not sound like a problem USB recovery will help with. When boot from flash fails, there is usually more on the display. It doesn't particularly sound like a power supply issue, either. Could be a RAM problem.
- JarnoGAug 24, 2020Guide
I had put in a 2GB RAM module from Corsair a long time ago. Luckily I saved the module that orignally came with the NAS. However, when I use the original module, I get the same result as with the Corsair module.
- SandsharkAug 25, 2020Sensei
I would not recommend you purchase a replacement supply and try that -- very low probability of success. However, you can create an adapter cable for a standard ATX supply mounted externally and see if that works -- it's a lot cheaper to just see if that will work or to use it to recover any files not already backed up. But since you were already running OS6, you can just put the drives in a newer NAS designed for OS6 and all should be well, assuming whatever took out the NAS didn't damage the volume.
