Mook1
Aug 10, 2016Guide
Ultra 6 Memory Upgrade Verification
I want to upgrade the memory on my Ultra 6s. I have two. 8GB seems a little pricey so 4B will have tp do. I've searched the forum and want to verify which memory is correct for the Ultra 6. Can someo...
- Aug 12, 2016
Here you are. It is the ReadyNAS Ultra 6 (Not Ultra 6 Plus), the CPU is the Intel Atom D510. 2x2Gb
Mook1
Aug 11, 2016Guide
Not sure that previous post does answer my question.
I'd appreciated verification of what memory I need. I hate returns.
Thanks.
- StephenBAug 11, 2016Guru - Experienced User
That'
Well, when I upgraded my pro-6 a while back I went with Patriot Signature Line 8GB DDR2 800 PC2 6400 Memory Module PSD28G800K That's been in place for about a year, and I haven't run into any issues.
Though I don't know if that will work out as well on your ultra (and it is 2x4GB, not 2x2GB).
- Mook1Aug 11, 2016Guide
Stephen, thanks. So many legacy models I'm just not sure. Ditto on memory. Too many choices. If I weren't ordering online it wouldn't be a big deal for a return.
sotrack, I'd appreciate that. Thank you.
- mdgm-ntgrAug 11, 2016NETGEAR Employee Retired
Make sure it is a ReadyNAS Ultra 6 (Not Ultra 6 Plus), The CPU in the Ultra 6 is the Intel Atom D510:
http://ark.intel.com/products/43098/Intel-Atom-Processor-D510-1M-Cache-1_66-GHz
It has two DIMM (Not SODIMM) slots, supports up to maximum of 4GB (2GB each slot DDR2 667/800). Default was 1GBThe Ultra 6 (RNDU6000) and Ultra 6 Plus (RNDP600U) have very different hardware.
Hi mdgm,
It's an Ultra 6 not Ultra 6 Plus.
From Frontview:
Model: ReadyNAS Ultra 6 [X-RAID2] Serial: 2EE107R60017D Firmware: RAIDiator 4.2.27 Memory: 1024 MB [DDR2] That's one of the things that's confusing. The photos on the early Ultra user guides and the website show a picture of the NV series.
In my seraching I checked Hardware Compalibility for memory and got "Page Not Found".
http://kb.netgear.com/app/error//error_id/1
Saw Stephen's posts about the Pro 6. Saw posts about the Ultra 6 Plus.
I could go on but I'll stop. :)
I'm just a tad bit confused and need some verification. Any clarification is helpful.
Thanks.
