Mook1
Aug 10, 2016Guide
Ultra 6 Memory Upgrade Verification
I want to upgrade the memory on my Ultra 6s. I have two. 8GB seems a little pricey so 4B will have tp do. I've searched the forum and want to verify which memory is correct for the Ultra 6. Can someo...
- Aug 12, 2016
Here you are. It is the ReadyNAS Ultra 6 (Not Ultra 6 Plus), the CPU is the Intel Atom D510. 2x2Gb
Mook1
Aug 11, 2016Guide
Not sure that previous post does answer my question.
I'd appreciated verification of what memory I need. I hate returns.
Thanks.
Aug 11, 2016Guru - Experienced User
That'
Well, when I upgraded my pro-6 a while back I went with Patriot Signature Line 8GB DDR2 800 PC2 6400 Memory Module PSD28G800K That's been in place for about a year, and I haven't run into any issues.
Though I don't know if that will work out as well on your ultra (and it is 2x4GB, not 2x2GB).
