Mook1
Aug 10, 2016Guide
Ultra 6 Memory Upgrade Verification
I want to upgrade the memory on my Ultra 6s. I have two. 8GB seems a little pricey so 4B will have tp do. I've searched the forum and want to verify which memory is correct for the Ultra 6. Can someo...
- Aug 12, 2016
Here you are. It is the ReadyNAS Ultra 6 (Not Ultra 6 Plus), the CPU is the Intel Atom D510. 2x2Gb
Mook1
Aug 11, 2016Guide
Hi mdgm,
It's an Ultra 6 not Ultra 6 Plus.
From Frontview:
| Model: | ReadyNAS Ultra 6 [X-RAID2] |
| Serial: | 2EE107R60017D |
| Firmware: | RAIDiator 4.2.27 |
| Memory: | 1024 MB [DDR2] |
That's one of the things that's confusing. The photos on the early Ultra user guides and the website show a picture of the NV series.
In my seraching I checked Hardware Compalibility for memory and got "Page Not Found".
http://kb.netgear.com/app/error//error_id/1
Saw Stephen's posts about the Pro 6. Saw posts about the Ultra 6 Plus.
I could go on but I'll stop. :)
I'm just a tad bit confused and need some verification. Any clarification is helpful.
Thanks.
sotrack
Aug 12, 2016Luminary
- JanHussaarts2Aug 12, 2016Luminary
I have an Ultra 6 too.
Recently I have added an extra 1 GB PC2-6400.
Just in case OS6 would require more.
So I have 2 GB know, that seems to be enough in my situation.
- Mook1Aug 12, 2016Guide
Jan, thanks for your reply.
sotrack, that's the ticket!
Thanks. I've ordered 2 sets for both my Uttras.
- StephenBAug 12, 2016Guru - Experienced User
Let us know how the upgrade goes!
- Mook1Aug 18, 2016Guide
Memory rec'd and memory test running on first unit.
For the life of me I could not remove the motherboard. after taking out the 6 screws I was having to apply too much force.
Thankfully, I have small hands and was able to snap the memory in.
I have one more unit to do assuming things go well with unit 1.
Any tips on removing the mobo?
Will report success or failure. Thanks for all the help esp. sotrack's pic.
