Paul_P
May 28, 2020Tutor
Unable to change county on Netgear profile, preventing ordering of ProSupport for Home
FAO Netgear Support, I purchased a Netgear ReadyNAS 526 NAS in 2017, which has been working fine until recently when I some of my shares disappeared after a firmware upgrade (they are no longer v...
- May 30, 2020
The script is here. Before you run it, you should verify via SSH that the shares are actually still there and the OS partition is not full or nearly so. Making a backup would also be a good idea, but that can be a bit of a pain from SSH. I didn't write it, but I have studied it. It seems pretty bullet proof -- it may not fix the problem but should do no harm unless the OS partition is full. Even then, it will likely just fail and do no harm, but I wouldn't count on it.
The script verifies that the shares are actual BTRSFS subvolumes (which yours must be since they once worked) and re-writes the "special sauce" files for the shares to be seen by the GUI as well as some configurations (like SMB). After running it, you should reboot, Then, go reset the share permissions to be what you want,
JohnCM_S
May 28, 2020NETGEAR Employee Retired
Hi Paul_P,
We will check on this one. Just to be sure, can you send me via private message the email that you are using for your myNETGEAR account?
