Paul_P
May 28, 2020Tutor
Unable to change county on Netgear profile, preventing ordering of ProSupport for Home
FAO Netgear Support, I purchased a Netgear ReadyNAS 526 NAS in 2017, which has been working fine until recently when I some of my shares disappeared after a firmware upgrade (they are no longer v...
- May 30, 2020
The script is here. Before you run it, you should verify via SSH that the shares are actually still there and the OS partition is not full or nearly so. Making a backup would also be a good idea, but that can be a bit of a pain from SSH. I didn't write it, but I have studied it. It seems pretty bullet proof -- it may not fix the problem but should do no harm unless the OS partition is full. Even then, it will likely just fail and do no harm, but I wouldn't count on it.
The script verifies that the shares are actual BTRSFS subvolumes (which yours must be since they once worked) and re-writes the "special sauce" files for the shares to be seen by the GUI as well as some configurations (like SMB). After running it, you should reboot, Then, go reset the share permissions to be what you want,
Paul_P
May 28, 2020Tutor
Hi John,
I've logged out of www.netgear.com and logged back in again. I then went to My Account -> My Products, selected the NAS from the list, and then clicked 'Purchase Service Contract' button.
The next page then shows me two options, a 1-year service contract, and a 3-year service contract, both priced in British Pounds Sterling, which is correct so far. However, when I select the one year contract, and click 'Submit' button, this takes me to the Checkout page to complete my address and credit card details, but it is now showing the price in US dollars (NB: the figures are the same, but GBP symbol £ has changed to USD symbol $).
When I try to save my billing address (in the UK), I get the same error message as before "New plan does not have a rate schedule with a currency matching the account's currency." So I can't proceed any further.
If I go back and view my profile, it is still showing my address as being in US not UK which is still wrong. So, does the change take some time to propagate or is it instantaneous? Or does something else on my account need to be changed (e.g. related to currency)?
Best regards,
Paul
JohnCM_S
May 28, 2020NETGEAR Employee Retired
Hi Paul_P,
We will check on this one again. I will provide you an update as soon as possible.
- SandsharkMay 28, 2020Sensei
Are you comfortable with SSH and the Linux command shell? If so, there is a script that you can run that may fix your problem. I don't have a link to it handy, but one of the mods can provide it.
- Paul_PMay 29, 2020Tutor
Hi Sandshark,
I would be able to enable SSH and run a Linux script on my NAS. So if someone is able to send me the relevant Linux script I would appreciate it.Best regards,
Paul
- JohnCM_SMay 29, 2020NETGEAR Employee Retired
Hi Paul,
Can you also provide me via private message the S/N of the NAS on which you are trying to purchase the support contract?
Also regarding the issue on your NAS, are the users able to see the shares via file explorer? Are you just not able to see it on the web admin page?
