BH9244
Apr 01, 2019Aspirant
Unable to Delete Files
Greetings, I have a RN214 unit configured in RAID5 with 4 2TB Drives, the unit is down to about 25MB of free space and I seem to be unable to delete files off of it to free up space.
When I sel...
Apr 01, 2019Guru - Experienced User
What firmware are you running?
Have you looked in the log zip file for any clues (e.g, errors)?
If you haven't backed up the NAS, I suggest that you do that. One option is to destroy the current volume, create a new one, and then restore data from the backup.
- BH9244Apr 01, 2019Aspirant
Running 6.9.5
Ok I checked the log and there's a recent entry that says "the volume encountered a error and was made read-only" so I guess that answers the inability to delete files, can that attribute be reset to read/write ?
- HopchenApr 01, 2019Prodigy
Hey BH9244
The errors are like because the filesystem would not like being so full. You always gotta leave a bit of wriggle room for transactions on the filesystem, etc.
I can take a look at the logs if you like. Download them and attach to Google link or similar and PM me the link.
I will agree with StephenB here. Definitely time to do a backup if you don't have one already.
Cheers
- StephenBApr 01, 2019Guru - Experienced User
It was set read-only in order to prevent further damage to the file system..
The safest way to proceed is to back up the data, and recreate the volume.
Ok, in process now. Thanks for the help won't cut so close in the future.
