BH9244
Apr 01, 2019Aspirant
Unable to Delete Files
Greetings, I have a RN214 unit configured in RAID5 with 4 2TB Drives, the unit is down to about 25MB of free space and I seem to be unable to delete files off of it to free up space.
When I sel...
Apr 01, 2019Guru - Experienced User
What firmware are you running?
Have you looked in the log zip file for any clues (e.g, errors)?
If you haven't backed up the NAS, I suggest that you do that. One option is to destroy the current volume, create a new one, and then restore data from the backup.
BH9244
Ok I checked the log and there's a recent entry that says "the volume encountered a error and was made read-only" so I guess that answers the inability to delete files, can that attribute be reset to read/write ?
- HopchenApr 01, 2019Prodigy
Hey BH9244
The errors are like because the filesystem would not like being so full. You always gotta leave a bit of wriggle room for transactions on the filesystem, etc.
I can take a look at the logs if you like. Download them and attach to Google link or similar and PM me the link.
I will agree with StephenB here. Definitely time to do a backup if you don't have one already.
Cheers
- StephenBApr 01, 2019Guru - Experienced User
It was set read-only in order to prevent further damage to the file system..
The safest way to proceed is to back up the data, and recreate the volume.
- BH9244Apr 01, 2019Aspirant
Ok, in process now. Thanks for the help won't cut so close in the future.
