SLK-Purdue
May 03, 2022Luminary
Unable to send Alerts via Sign in with Google
Google is making changes is the area and looks like latest ReadyNAS FW stopped being able to send Alerts with Google on May 1, 2022. Scott Model: ReadyNAS 312 Firmware: 6.10.7 Context: syst...
JeraldM
May 04, 2022NETGEAR Employee Retired
Hi SLK-Purdue,
Thanks for the ping StephenB!
I tried testing this out and it seems to be working on my end.
I also had "less secure apps" option disabled and the test message was sent to my email.
And just to confirm, after signing in with your Google account, is the screenshot provided below the same as yours?
JeraldM
NETGEAR Community Team
SLK-Purdue
May 05, 2022Luminary
Here is log entry in msmtp.log from most recent attempt
May 05 11:25:15 host=smtp.gmail.com tls=on auth=on [email protected] [email protected] [email protected],[email protected]@purdue.edu,[email protected] smtpstatus=530 smtpmsg='530-5.7.0 Authentication Required. Learn more at\n530 5.7.0 https://support.google.com/mail/?p=WantAuthError n12-20020a92dd0c000000b002cde6e352basm526121ilm.4 - gsmtp' errormsg='envelope from address [email protected] not accepted by the server' exitcode=EX_DATAERR
Looks like an auth issue but I have confirmed my auth is valid.
- JeraldMMay 05, 2022NETGEAR Employee Retired
Hi SLK-Purdue,
It does look like an auth issue and I assume the most recent attempt was when you manually set it up, right?
In this case, would it be possible if you could try signing in Google using an incognito browser and if possible, removing all of the alert contacts as well?
JeraldM
- SLK-PurdueMay 05, 2022Luminary
yea, most recent attempt to manually sent.
I will try as you suggest and let you know.
Scott
JeraldM wrote:Hi SLK-Purdue,
JeraldM
I did a "logout", "clear" and manually entered the gmail information. That now seems to be working. Not sure what that means but will monitor it for a few days.
Thanks,
Scott
JeraldM
