adinb
Jul 03, 2006Aspirant
Unison Support?
I'd like to throw support for Unison (client & server) into the hat. It's cross platform, similar to rsync, but easier to use, and has plenty of F/OSS implementations. Unison might really make mirrori...
bindertwine
Sep 08, 2007Aspirant
Well, if dpkg is implemented on the readynas (I don't know), you can probably install it easily enough. After radiator 4 is released, I'd be willing to try it myself.
Although it isn't true that running unison locally misses the whole point - after all, you are still achieving file synchronization. It's just a whole lot slower than it ought to be. But better than nothing.
