CRUZZIN7
Aug 17, 2019Aspirant
update rnd2150v2 from raidar 4.1.1.6 to raidiator arm 5.3.11
okay oldtimers...I need your help... I have a rnd2150v2 (yes v2 and for some reason it never shows up on any previous model). It is stamped on the back with a sticker rnd2150v2. Everything i...
- Aug 17, 2019
Raidiator 4.1.1.6 firmware is the correct firmware version for your ReadyNAS
Raidiator 5.3.11. is NOT, so do not even go there
bedlam1
Aug 17, 2019Prodigy
Aug 17, 2019Guru - Experienced User
4.1.16 :smileywink:
CRUZZIN7 The v2 label doesn't mean that you think it does. You have a sparc-based NAS (called a v1 here). The Arm based NAS (which does run 5.3.x firmware) would say "Duo v2" on the front chassis - not buried in the part number.
- CRUZZIN7Aug 17, 2019AspirantThank you for clearing that up :)
- CRUZZIN7Aug 17, 2019AspirantThank you. So raider is as far as it goes huh? Lol
- CRUZZIN7Aug 17, 2019AspirantRaidar*
- StephenBAug 18, 2019Guru - Experienced User
CRUZZIN7 wrote:
Thank you. So raidar is as far as it goes huh? LolRAIDar is a PC application. https://kb.netgear.com/20684/ReadyNAS-Downloads
The firmware on your NAS is branded RAIDiator, and 4.1.16 is the final version. Netgear stopped manufacturing it in 2011, and stopped releasing firmware updates in 2017.
The current entry-level ReadyNAS is the RN212, which runs OS 6. It's a lot faster and has more features than your Duo.
Is there an issue with your current NAS? Or were you just checking to see if you were running the latest firmware?
- CRUZZIN7Aug 20, 2019Aspirant
I am not currently experiencing any problems with it just wanted to push the envelope a little more. For some reason i thought the version was a 2 when i bought it and it's just the old v1. i currently use it for my home networking and with the external usb ports I'm currently getting a whopping 18 terrabytes...so I'm good just hanging onto the grandfathered super reliable NAS.
Thanks for your time...it's much appreciated!
