nateclaflin
Feb 06, 2017Follower
Upgrade RAM on RN52(4/6)X
Thinking about upgrading the memory, is anyone aware on whether this has a full DDR4 DIMM or is it a SODIMM stick.
Feb 06, 2017Guru - Experienced User
The 62x products use a DIMM, so I think the 52x do also.
mdgm-ntgr
Feb 06, 2017NETGEAR Employee Retired
Replacing the memory is a difficult task and we don't support doing that, but it is replaceable.
- StephenBFeb 07, 2017Guru - Experienced User
My recollection is that getting access to the DIMM slots is more difficult with the 52x and 62x models than it is with the Pro-6.
- aalexandrebetaFeb 09, 2017Master
By the way opening the box void the warranty!!!
So watch out!
- StephenBFeb 09, 2017Guru - Experienced User
So watch out!
I didn't actually take it apart, and the screws I played with aren't sealed in any way.
But yes, you do risk voiding the warranty.
