Paul-U
Sep 01, 2021Aspirant
upgraded to windows 10 and my SC101T no loner works
I have been using my SC101T for a few years on my old Windows 2003 maching without issues, all my backup files are stored on it. I know the unit is working fine but I cannot get it to work via windo...
Sep 01, 2021Guru - Experienced User
Paul-U wrote:
I have been using my SC101T for a few years on my old Windows 2003 maching without issues, all my backup files are stored on it. I know the unit is working fine but I cannot get it to work via windows 10, i need to get some files from the drive.
what can i do, will i be able to find a different nas that will accept the HDDs i used in the SC101T and read the files?
any ideas please
ReadyNAS can not accept those disks, and AFAIK there are no other products from any manufacturer that are compatible with this technology.
You could try enabling the SMB1 client on your Windows 10 system, and see if that helps. But if your Windows 2003 system is still in service, I suggest that you copy off the files to external storage and then look for a different solution.
