Paul-U
Sep 01, 2021Aspirant
upgraded to windows 10 and my SC101T no loner works
I have been using my SC101T for a few years on my old Windows 2003 maching without issues, all my backup files are stored on it. I know the unit is working fine but I cannot get it to work via windo...
Paul-U
SMB1 Client is enabled but does nothing.
The old machine is out of order.. oh sorry for thetypos in my original post.
Sep 01, 2021Guru - Experienced User
I guess that is because it is a SAN and not a NAS. Likely you need the SCM utility running on the PC (which might not be compatible with Win10). I saw some stuff on the web that suggests the utility can only be installed on 32 bit PCs.
