Paul-U
Sep 01, 2021Aspirant
upgraded to windows 10 and my SC101T no loner works
I have been using my SC101T for a few years on my old Windows 2003 maching without issues, all my backup files are stored on it. I know the unit is working fine but I cannot get it to work via windo...
Sep 01, 2021Guru - Experienced User
Paul-U wrote:
SMB1 Client is enabled but does nothing.
I guess that is because it is a SAN and not a NAS. Likely you need the SCM utility running on the PC (which might not be compatible with Win10). I saw some stuff on the web that suggests the utility can only be installed on 32 bit PCs.
Sandshark
Sep 02, 2021Sensei
The best solution, assuming no access to a computer with a legacy OS, is to create a virtual machine and use it to access the system and transfer the files. You should be able to do that with an unregistered version of the OS before it expires. But the easiest way to create the VM would be to see if one available from Microsoft (that do expire, but don't complain about being unregistered) will work: https://developer.microsoft.com/en-us/microsoft-edge/tools/vms/ .
