mathiourose
Feb 08, 2017Aspirant
upgrading capacity
Hi - I have a RN314 with 4 x 3TB hdd. I am looking to upgrade my capacity and was considering a) getting 4 x 6 TB for the 314 or b) a 312 with 2 x 10TB - and keeping the 314. Any thoughts... would 2 ...
aalexandrebeta
Feb 09, 2017Master
It really depends on what you are looking for!!
In a cost effective sense of way 4x6Tb is better than an other unit plus the 10TB X 2 purchase .
As far as I am concerned!
And recycle your old drives in an obsolete NAS or entry level NAS to double back up your critical datas!
- mathiouroseFeb 09, 2017Aspirant
Thanks for the comments - I think I will replace 2 of the 3TB with 2 x 8TB now and then 2 x 8TB later.
Cheers
- aalexandrebetaFeb 09, 2017Master
You are welcome!
Keep me in the loop!
Have a nice day.
If you are satified kudoe appriciated!
