mrg9999-01
Jul 01, 2024Aspirant
Upgrading disks in RN316
I have RN316 with 5 x 4TB disks, X-RAID. I wish to change these for 3 x 12TB from the supported list. Which method is best / quickest. I have the NAS connected to a UPS. A. Remove all the existing...
mrg9999-01
Jul 02, 2024Aspirant
Thanks for the reply
Remove all the existing disks, insert 3 x 12TB giving 24TB raid 5 and restore the data.
All other options require use of Linux commands to shrink the array from 5 disks to 3.
What are these commands / is there a guide?
I found this
https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/Reducing-RAID-size-removing-drives-WITHOUT-DATA-LOSS-is-possible/td-p/1736125
>But if the 4TB disks are healthy...
They're OK, but these 4TB are 10+ years old. Its main function is a snapshot/backup to another brand of NAS.
I'd like to add a 4th disk when prices come down or spares from other units become available.
Jul 02, 2024Guru - Experienced User
I found this
That is the guide. It's not info Netgear ever provided.
- SandsharkJul 02, 2024Sensei
Shrinking the volume gets much more complicated if you have drives of different sizes, and thus multiple volumes. Not recommended unless you have a fair amount of Linux experience.
Just swapping out 2 drives for larger ones now doesn't prevent future expansion, you'll just be replacing instead of adding a drive. But with drives that old, your idea of starting with all fresh drives is a sound one.
