Weasleish's avatar
Weasleish
Follower
Jul 07, 2022
Upgrading harddrive
So currently i run a ReadyNAS 104 with 4 x 4TB WD Red drives in it and they're nearly full. To increase my storage is it as simple as buying a 12TB WD Red and just swapping it in place of one of the 4TB ones? From what i've read i do this while it's still turned on and it should just adjust itself to the new storage?
1 Reply
  • Assuming you are using XRAID/RAID5, you'll have to replace two drive to get a size increase.  Yes, you swap them out with power on.  The first one will just re-sync the existing volume size.  The second one will first re-sync that, then sync a second layer with the first larger drive, which will add to the available space.
ProSupport for Business
