remtule
Aug 11, 2020Aspirant
Upgrading To a new NAs
Hi all, Sorry if i have posted this in the incorrect forum. So after ten years, my readynas nv+ (RND4000) died, i thought it was the power supply so got a replacement power supply but looks like...
JohnCM_S
Aug 11, 2020NETGEAR Employee Retired
Hi remtule,
Welcome to the Community!
Yes, it is possible to recover the data from the volume of your legacy ReadyNAS using the new ReadyNAS OS 6 chassis.
Due to differences in CPU architecture and operating systems, some additional steps are required for you to be able to recover the data. To make the data accessible, some assistance from NETGEAR Support.
You may check this article for detailed steps on how you can recover your data using the ReadyNAS OS6 chassis.
remtule
Hey John
thanks for the response and the link
i've read the link but i'm a little confused
So, Do you insert the spare disk at the same time as the Original array is in?
Does it also mean i need to purcahse a 5 bay nas to get this done? I'm happy to do so if this is the case i just need to make certain i make the correct initial purchase, i'd hate to buy a 4 bay only to find out i need a 5 or 6 bay to get this going.
Thanks
Matt
- StephenBAug 12, 2020Guru - Experienced User
You insert the spare disk at the beginning, and you don't add your own disks until you contact support for instructions.
Although I haven't run this procedure, I believe the spare disk is removed, and the NAS is booted up with only the old disks in the NAS. Then support would manually mount the old array. JohnCM_S will hopefully confirm.
Note this is just temporary - once mounted, you need to copy off the data to other storage (for instance a USB drive).
remtule wrote:
Any help in not losing this crucial data would be ideal as this contains alot of my life.
After you get the data migrated, I suggest that you put a proper backup plan in place for the NAS. RAID just isn't enough to keep your data safe - you need at least one copy on another device.
If you get a USB drive to offload the data, then you could use that same drive to back up the new NAS.
- JohnCM_SAug 12, 2020NETGEAR Employee Retired
Hi all,
Although I haven't run this procedure, I believe the spare disk is removed, and the NAS is booted up with only the old disks in the NAS. Then support would manually mount the old array. @JohnCM_S will hopefully confirm.
Yes, this is correct.
- JohnCM_SAug 15, 2020NETGEAR Employee Retired
Hi remtule,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
