remtule
Aug 11, 2020Aspirant
Upgrading To a new NAs
Hi all, Sorry if i have posted this in the incorrect forum. So after ten years, my readynas nv+ (RND4000) died, i thought it was the power supply so got a replacement power supply but looks like...
remtule
Hey John
thanks for the response and the link
i've read the link but i'm a little confused
So, Do you insert the spare disk at the same time as the Original array is in?
Does it also mean i need to purcahse a 5 bay nas to get this done? I'm happy to do so if this is the case i just need to make certain i make the correct initial purchase, i'd hate to buy a 4 bay only to find out i need a 5 or 6 bay to get this going.
Thanks
Matt
Aug 12, 2020Guru - Experienced User
You insert the spare disk at the beginning, and you don't add your own disks until you contact support for instructions.
Although I haven't run this procedure, I believe the spare disk is removed, and the NAS is booted up with only the old disks in the NAS. Then support would manually mount the old array. JohnCM_S will hopefully confirm.
Note this is just temporary - once mounted, you need to copy off the data to other storage (for instance a USB drive).
remtule wrote:
Any help in not losing this crucial data would be ideal as this contains alot of my life.
After you get the data migrated, I suggest that you put a proper backup plan in place for the NAS. RAID just isn't enough to keep your data safe - you need at least one copy on another device.
If you get a USB drive to offload the data, then you could use that same drive to back up the new NAS.
- JohnCM_SAug 12, 2020NETGEAR Employee Retired
Hi all,
Although I haven't run this procedure, I believe the spare disk is removed, and the NAS is booted up with only the old disks in the NAS. Then support would manually mount the old array. @JohnCM_S will hopefully confirm.
Yes, this is correct.
