chrisl1
May 09, 2017Aspirant
Urgently need my NAS up and running. Stuck on Please wait, Booting....
Model RND4410 Has been working fine for years. Now when I switch it on it hangs on Booting please wait. Blue light flashing, disk drives lights don't come on. Device is on and can be heard. ...
chrisl1
May 12, 2017Aspirant
Guys, I have finally managed to find the bad disk it is making a weezing noise and it shows as 4GB in total instead of 1TB.
Now if I put the labelled disks back into netgear will no data loss occur if I replace the failed drive with a new one, will the volume rebuild with minimal data loss?
Shutting the system down before it goes to check the volume would be ok?
May 12, 2017Guru - Experienced User
Your NV+ v1 NAS uses a dedicated parity disk, and I believe that is the disk that failed. Those parity blocks are written to an unpartitioned area of the disk.
Was this disk in slot 4? Usually the parity disk is in that slot.
Assuming you've correctly identified the failing disk, It should boot up without that disk in place.
In general RAID tends to be all-or-nothing. When you add a disk, the system should resync with no data loss. If that process fails (due to a second failed disk) then you will lose everything.
There is a boot option to skip the volume check, and you should use it in this case. Then make a backup before doing anything else.
See pages 23-24 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
