chrisl1
May 09, 2017Aspirant
Urgently need my NAS up and running. Stuck on Please wait, Booting....
Model RND4410 Has been working fine for years. Now when I switch it on it hangs on Booting please wait. Blue light flashing, disk drives lights don't come on. Device is on and can be heard. ...
chrisl1
May 12, 2017Aspirant
Hi Stephen
No, It is Disk 2. Should I boot with Knoppix and try copy all data off the disks first before I put the working ones in net gear just in case I have another failed disk ?
May 12, 2017Guru - Experienced User
That is reasonable option. There is a guide here: http://home.bott.ca/webserver/?p=306
chrisl1 wrote:
No, It is Disk 2.
It still is possible that is the parity disk - there should be exactly one that doesn't have a partition for the C volume.
