jimk1963
Dec 22, 2023Virtuoso
Use external SATA cloning dock to expand NAS
My RN528 came with 8x4TB Toshiba HDD’s. Using X-RAID I have about 21TB of usable space (if memory serves, might be a little higher). Presently about 10TB is populated. Considering swapping in 4 1...
Dec 22, 2023Guru - Experienced User
The tradeoff here:
Hotswapping 4 disks one at a time will certainly take more time. But the NAS remains in service throughout the process (though the performance won't be as good as usual).
There are alternatives that will complete more quickly, but the NAS will be down while you are doing them, and they have a lot more manual steps.
So one obvious question is why you need to hurry. You are using only 50% of the NAS storage today, so there is no urgent reason to expand.
Also, it sounds like you have no backup plan in place for the NAS. RAID (even dual redundancy) isn't enough to keep your data safe. Personally I would take care of that before thinking about expansion.
One option is to purchase a 5th 16 TB drive and use it to back up your data. Then add additional backup disks as the capacity grows. You could put this fifth drive into a suitable enclosure and connect it to a PC (doing the backups over the network). I've gone with a different approach myself - backing up to other NAS. While more expensive to set up, it is easy to fully automate and easy to expand as my storage grows.
FWIW, I have a similar model to the Sabrent you linked (mine has USB-C cabling) that I picked up a couple of years ago. I've had no issues with it. It is suitable for temprary use (cloning, disk testing, disk erasing, etc). But it not the best choice for more permanent use (like backup), since the disks aren't secured in place. You'd want something where the disks can't be accidently disconnected.
The NAS reports space in TiB but labels it as TB (same as Windows).The capacity rule for dual redundancy is sum the disks and subtract the largest two.
Your current capacity is 24 TB (~21.8 TiB). 4x16 + 4x4 will give you 48 TB (~43.7 TiB), so twice the space.
jimk1963 wrote:
I understand one upgrade method is to swap out a single drive, wait for resync, swap out the second drive, wait again for resync, and so on. Having gone through a few same-capacity drive swap-outs with various NAS’s (including this one), I found the resync time to be very long. I think the last one I did took more than a day.
It takes a while because every sector in the volume is either read or written during the each replacement.
So 32 TB of I/O for each of the first three replacements. The fourth disk will take more twice as long, since due to the expansion you will have 80 TB of I/O. Total I/O for all four then is 176 TB.
jimk1963 wrote:
Alternatively, if I had a 4-bay external SATA dock, could I just install the four 16TB drives in it and copy the entire NAS over to these larger drives, and then swap out the first 4 4TB drives with the 16TB’s? I’m guessing this wouldn’t work at all, but am not sure.
This won't work.
But you could copy all the data to a single 16 TB drive temporarily connected to a PC, since you only have 10 TB of data altogether.
Then install 3x16TB + 4x4TB in the NAS (leaving one slot empty), and do a factory install. Reconfigure the NAS shares and copy the data back. Then add the last disk to the volume.
Disk I/O for the initial volume build is 32 TB, plus 20 TB of copying, plus 80 TB for the last step. So about 132 TB altogether. So it will be faster (though more manual steps) than replacing one disk at a time.
FWIW, if you put a backup plan in place first (as I suggested above), then you could do a factory reset with 4x16TB + 4x4TB in place, reconfigure the NAS, and restore the data from backup. That would take about 90 TB of disk I/O (not counting creating the backup).
jimk1963 wrote:
https://sabrent.com/products/ec-hd2b
I see that these docking stations perform cloning. So my question is, instead of trudging through resyncs x 4, is it technically feasible to clone each 4TB drive (say, drives 1 through 4) to 4 new 16TB drives, and then simply install the new 16TB drives without any subsequent rebuilding or other “work” on the part of the NAS?
Sector by sector cloning would certainly be faster if it works. 32 TB of I/O for the cloning. The volume expansion would take another 48 TB of I/O when the NAS first boots up (so you aren't avoiding all the rebuilding). Still, only 80 TB of disk I/O altogether. You would have to keep the NAS powered down during the entire cloning process
The risk is that the NAS might not expand the volume when you boot it up after cloning.
Sandshark
Dec 22, 2023Sensei
StephenB wrote:You would have to keep the NAS powered down during the entire cloning process
The biggest issue with your proposed "solution" is that the NAS has to stay off during the process. If it's on and one of the drives is not present, then that removed drive becomes out of sync with the volume and would still need to go through a full re-sync when placed in the NAS, defeating the whole purpose. While normal expansion does take time, you have access to your data as it occurs. Here, you don't.
If you did do that, I think the NAS would do the expansion or could be forced to via an SSH command. If you do a normal one drive at a time expansion, the NAS does not create a partition in the expanded space until it's able to do an expansion, so it's at the same point as your cloned unit would be before it starts the expansion.
- StephenBDec 22, 2023Guru - Experienced User
Sandshark wrote:If you did do that, I think the NAS would do the expansion or could be forced to via an SSH command.
I agree it should.
I recall one poster saying it didn't in his case, so thought the risk was worth pointing out.
- jimk1963Dec 22, 2023Virtuoso
Thanks StephenB and Sandshark , as usual you guys are a national treasure when it comes to these things.
Few explanations for this whacky idea, to address your replies:
1) Not in any hurry to rebuild, at all. Swapping in one disk at a time, with low risk, would work just fine. Reason for inquiring about this was because (a) I hadn't found any posts discussing this cloning approach, which surprised me, and (b) although I'm in no hurry, and I don't care if the NAS is shut down for a bit, it seemed like simply cloning drives was a much faster process, with greatly reduced HDD I/O, and I was curious why it isn't done more often. After reading your replies, maybe it isn't any simpler in the end, and appears to have a volume expansion risk that could create more work (SSH commands - always a joy to re-learn for us non-power users).
2) I also have multiple NAS units (RN528, RN424, RN212, also an RN314 that's not in use at the moment). My "main" NAS is the 528, due to its 10GbE interface (my home network is all 10GbE and WiFi 6E). The other NAS's are only 1GbE, with clunky CPU's, and are painfully slow to do just about anything (opinion). I have backed up the main NAS onto these older NAS units, but not "bit for bit"... rather I've backed up folders over time, and so the other 2 NAS units don't have a "perfect" clone of the 528. (I have found RSYNC to be (a) very finicky to set up, in particular choosing folders/shares/whatever, and (b) backups sometimes fail inexplicably.) I could remedy that of course, with some effort, and need to do so eventually. Also still need an offsite solution, I've been investigating cloud options, liking Backblaze and maybe Synology after first look. More research to do.
3) Am not thinking of these docking stations as backup units, not in the least. As noted, my initial interest was really just to run Seatools on new drives per your suggestion, without having to dig into my tower and futz with SATA cables/mounting/etc. Glad to read you are using one of these with success for things like that. It was the easy one-button cloning option on these docking stations that got me thinking about the subject of this thread.
4) Your suggestion to buy a single 16TB HDD and copy everything to that is a great idea, may just do that, in addition to making sure the other NAS units have true back-ups.
Is there a user friendly 3rd party software tool that can be used to backup one NAS to another, instead of using the clunky ReadyNAS OS?
- StephenBDec 23, 2023Guru - Experienced User
FWIW, my main NAS is an RN526, the backups are an RN524, an RN202 (using jbod), and a Pro-6 with upgraded RAM (and running OS-6). One backs up on Monday, Wednesday, Friday; the second backs up on Tuesday, Thursday, Saturday; the third back ups on Sunday. All are UPS protected (as are my switches). The backups are on a power schedule, so normally only on during backup (or during scheduled maintenance jobs). So at least one backup NAS is always off (and most of the time, all three are off). The backup NAS also have all file sharing protocols disabled (only set up for rsync).
This is overkill, but I happen to have those NAS, so I figure I might as well use them. If/when one of the back up NAS fails, I'd switch to having one back up daily (Monday - Saturday) and the second back up weekly (Sunday).
As I mentioned in the hacking thread (that you are also posting on), I personally don't run apps on the NAS itself. So I'd limit myself to software that runs on a separate PC. That wouldn't be very efficient, as all the transfers (and analysis of what needs to be backed up) would need to go through the PC.
I have set up share-by-share backup jobs on the backup NAS, and those use rsync. I haven't seen seen rsync miss files, or back up jobs get aborted. That might be because the backup NAS are running the backup jobs.
Personally I use CrashPlan running on a PC that has the data volume mapped to a drive letter. Backup speeds are slow (and likely full recovery would be too). But I like the price, and the purpose is only disaster recovery. One drawback is that CrashPlan doesn't back up tib/tibx or vhd/vhdx files.
Though I could shift that to putting one of the backup NAS in a nearby family member's home.
