slav-dev
Aug 08, 2021Follower
Used ReadyNAS Duo Cant connect to Admin page RND 2175 Initial setup
Hi, just picked up used Readynas duo. I connect to set-up device (rnd 2175).
I have tried os- reinstal and put factory defaults by holding reset button at the back.
When i'm trying to connect do admin page connection is refused.
I went trough forum and didnt find any answer.
Can somebody advice?
1 Reply
- SandsharkSensei
You have to have a drive in it to be able to set it up. The OS runs off the drives, and all configuration is also saved there.
In case you didn't already find it in the forum, the default admin password for your Duo is netgear1.
