raymondc
May 03, 2018Tutor
Using ReadyNAS as Multicast Video Streaming Server
Any one try using ReadyNAS as a multicast video streaming server broadcasting video to LAN client?
raymondc
Jul 05, 2018Tutor
Just want to find a solution using ReadyNAS as a media server and broadcast video for clients (e.g. teaching material, live video, etc.)
Jul 06, 2018Guru - Experienced User
I don't know of any app for any ReadyNAS model that supports either multicast or live streaming. There are some linux packages that you could manually install (for instance VLC), but you would need to also deploy compatible clients. You'd need to do some work to automate (or semi-automate) what it streams.
What ReadyNAS model do you have, and what firmware is it running?
