fastfwd
Oct 15, 2013Virtuoso
WD Red drives park their heads like WD Green drives?
So I checked the SMART stats on my new 4TB Red drive (WD40EFRX) today. Imagine my surprise when I discovered that in only 249 power-on hours it has already experienced 36820 load/unload cycles!
Meanwhile, the 4TB Seagate drive (ST4000VN000) in that NAS, with the same number of power-on hours, has a load cycle count of... 2.
36820 load cycles in 249 hours is one load cycle every 24 seconds or so. According to Western Digital's marketing "datasheet", the drive is rated for 600K cycles; at this rate, my drive will reach that 600K threshold in only about another six months.
Is anyone else seeing this sort of crazy green-drive head parking behavior from WD Red drives?
- vandermerweMasterfastfwd, you say that WD agreed that you could return the drives under warranty.
Did you receive a refund or did you receive a different model WD drive as a replacement?
Interested to know as I am having problems returning these to the reseller as they maintain the drives are fit for purpose when clearly they are not. WD say they will send me a different model but they will be refurbished drives. - fastfwdVirtuosoI live in the USA and I purchased from Amazon. For the first drive, I received an identical replacement -- Amazon's policy is to ship the replacement and then allow 30 days for me to ship the old drive back, so I had both drives simultaneously for a time. For the second drive, I received a refund... Which I used to purchase a Seagate ST4000VN000 from Amazon.
I opened a support case with WD for each drive, and in each case their representative suggested that the drives could be returned to my place of purchase under warranty. I then referenced those support-case numbers in my correspondence with Amazon. - vandermerweMasterGreat thanks.
- I just bought a brand new WD30EFRX (3TB Red) with a production date of Oct '13 and it appears that it is still affected. I'm racking up 1K+ LCC's every 24 hours.
I don't understand - why would this happen on a drive that's on the HCL, and supposedly specifically for NAS use?
I don't have the luxury of exchanging so I plan on using WDIDLE3 - any opinions on S300 vs /D?
Thanks. - fastfwdVirtuoso
coreyinoz wrote: I just bought a brand new WD30EFRX (3TB Red) with a production date of Oct '13 and it appears that it is still affected. I'm racking up 1K+ LCC's every 24 hours.
That's interesting. Others have reported that the 3TB WD30EFRX drives does not have this problem, and that only the 4TB WD40EFRXs do.coreyinoz wrote: I don't have the luxury of exchanging so I plan on using WDIDLE3 - any opinions on S300 vs /D?
My opinion is that the NAS is happiest when it can control and be aware of what the drives are doing. So my preference would be to disable the timer with /d and then, if spindown is desired, to let noflushd handle that by enabling spindown in Frontview. - mdgm-ntgrNETGEAR Employee RetiredOdd. My WD30EFRX drives don't have high load cycle counts and I didn't need to run WDIDLE3 on them.
mdgm wrote: Odd. My WD30EFRX drives don't have high load cycle counts and I didn't need to run WDIDLE3 on them.
It's all very frustrating. That's what I was hoping for. Up to 2200 over 56 hours in the ReadyNAS...
My local PC shop will charge me a re-stocking fee to return this, and I just went through hours of work to migrate to this drive when I had heard about this and noticed my Green was up to 1.7M LLC.
Anand says that the Red's are defaulted to /d to begin with - so I'm going to set it to /300 and report back. I also have a ticket in with WD - if they ever answer...
To their credit, Netgear has come back and forth with me 3 times already - essentially pointing me to WDIDLE and washing their hands of it.- ocsoAspirantHi,
I can confirm that one of my WD30EFRX LCC value is increasing. I bought it yesterday and LCC value is 1112 after 24 hours.
I bought another WD30EFRX two weeks ago and after 14 days 10 hours operation its LCC value is: 7
Two disks have the same firmware (80.00A80) but the model ID is different:
1st HDD: WDC WD30EFRX-68AX9N0
2nd HDD: WDC WD30EFRX-68EUZN0 (parking heads)
According to the HD Sentinel: Acoustic management and Advanced Power management are not supported on these drives. - EtzAspirantInteresting, as both of my drives are already almost an year old, LLC count is still 2 and havent increased a notch... :roll:
Exact model is: WD30EFRX-68AX9N0 FW: 80.00A80 - vandermerweMastercoreyinoz and ocso
One of you at least as filed a case with WD, ocso have you done so?
WD need to be made aware of the level of customer dissatisfaction this issue is causing. It doesn't only affect Netgear products - Qnap and Synology are affected too.
WD need to feel that the complaints are going to affect sales, then they should act to fix it. In addition to submitting a case with WD you may consider posting reviews of the product on the site you purchased. I think some prospective buyers would want to know about this problem before making a purchase.
