XrayDoc88
Jun 15, 2021Apprentice
What Is "PRJNAME"?
I have the desktop ReadyCLOUD app installed on three home computers. On one of the three the desktop app says "ReadyCLOUD" next to the top icon. On the other two, it says "PRJNAME". Also, on the f...
Sandshark
Jun 16, 2021Sensei
It's an issue with Java. See if this previous post helps: Ready-Cloud-PRJNAME .
XrayDoc88
Jun 16, 2021Apprentice
Well that post shows that updating to the latest JAVA version didn't fix the problem. But installing some Microsoft .Net Framework patch in Windows 7 did. All of my computers are running Windows 10 64 Bit Pro. :(
- SandsharkJun 17, 2021Sensei
It's still a JAVA problem. Did you try updating or re-installing it? That didn't help for those running Win7, I didn't see a response from anyone runing Win10.
- XrayDoc88Jun 17, 2021Apprentice
I uninstalled JAVA and then reinstalled the latest version.. No change. I haven't uninstalled and reinstalled ReadyCLOUD yet. I'll try that next.
- siddamsettyJun 28, 2022Aspirant
Did the Issue got resolved, Request to reply what is the solution for this problem, as I have started with similar problem.
No content to show
