Killersystems51
Jun 28, 2020Aspirant
What switch to buy
I need a switch and I don't know what to buy I need poe I need for Home Security gaming ,NAS and home business smart home and I want 10gb please I have no clue what to buy
Marc_V wrote:
Well, you may need to look on 16-24 ports PoE Switch to make sure you accommodate all your equipments. You may want to take a look on the GS324TP or JGS524PE both are 1G switches with PoE Ports. if you are looking for 10G switches might as well check on the GC Family of switches.
You'd need 10GBASE-T with the ReadyNAS. I'm not seeing that with the GC family.
Getting PoE with multigig up to 10GB on all 16 ports will require a very expensive switch. For instance the XSM4316PB (over $2000). https://www.netgear.com/support/product/m4300-16x-600w-psu.aspx#docs
But you likely don't need that. You could combine two switches, for a lot lower cost. For instance, if your only 10GBase-T device is the ReadyNAS you could use two MS510TXPP switches https://www.netgear.com/support/product/MS510TXPP.aspx#docs for about $700.
Personally I use an XS708Ev2 combined with a GS728TPv2.
There are a lot of possible combinations - but the details matter. For instance, the PoE power budget, the number of 10GBase-T or multigig ports, and gigabit ports. The number of PoE ports (and whether they are gigabit or multigig) also affect the overall cost.
How many 10GBASE-T ports and how many POE ports do you need?
- Marc_VNETGEAR Employee Retired
Welcome to the Community!
I agree with StephenB, it will depend on what you need to power, how many ports and even how you want it to be installed. If you are looking for a NETGEAR Switch you can use the Switch Selector.
https://selector.netgear.com/productsearch/FormProductSelector.aspx
HTH
- Killersystems51Aspirantthe switch selector does not work on this site also I have 8 camera's 1 doorbell camera home theatre separates 5 computers and 2 tvs 1 projector and a NAS
- Killersystems51AspirantAnd 2 Soundbars
