dtarin's avatar
dtarin
Luminary
Sep 25, 2023
Who moved my cheese??
So there was a pretty good discusion going on regarding what to do with the existing readynas and maybe updating the OS on it.
Now the post is nowhere to be found and I get ACCESS DENIED on any links to the post that I had.  Can anyone else still access?
Updating-OS-to-something-modern
  • Did you mention Xpenology in it?  Just a guess, but if you did, it may have been removed since at least some of running Xpenology violates Synology's copyrights.  Netgear would probably remove it if Synology complained.
    • dtarin's avatar
      dtarin
      Luminary
      I didn't but I recall it was mentioned in the thread
      they were quick on the trigger for that!
      • tigerten's avatar
        tigerten
        Luminary
        Not convinced that is the reason. It was mentioned before and some of those thread are still live.
  • AnishaA's avatar
    AnishaA
    NETGEAR Employee Retired
    Hello dtarin ,
    Probably that would not be the reason for that. As tigerten  mentioned few posts are still available in the community which mentioned Xpenology!
    There is also a possibility that the post might be closed due to inaccessibility or due to no response, but still, you should be able to view the post.
    Could you please recall the subject you have given to that post? If yes please mention let us check from our end.
    Have a lovely day,
    Anisha A
    Netgear Team
ProSupport for Business
