t1addy
Dec 06, 2024Aspirant
Win11 24H2 and ReadyNAS
What did Microsoft do this time...? I allowed my Win11 Plex server to update to 24H2 today, and now it can't get to my ReadyNAS104. Firmware 6.10.10. I can get to it just fine with my desktop Win11...
Sandshark
Dec 06, 2024Sensei
"Can't get in" in what way? Can't load the UI? Can't access files via SMB? Or just a Plex issue? Does it show up in RAIDar?
Sandshark
Dec 10, 2024Sensei
Sounds like it might be related to this: Windows-11-24h2-may-block-connections-to-unsecured-third-party-nas-devices . The SMB Plus add-on does allow turning on SMB signing, so give that a try. My Win11 computer hasn't updated to 24H2 yet, so I can't. But I think I'll update a VM and see what happens.
- SandsharkDec 11, 2024Sensei
I just updated a VM to 24H2 and I have no problem accessing my NAS. I do have SMBPlus installed, but do not have SMB signing enabled. I'll have to see if I have a sandbox NAS without SMBPlus (I typically install it by default).
- StephenBDec 11, 2024Guru - Experienced User
FWIW, I just got a PC running 24H2, and it also reaches my NAS with no problems.
SMB Plus is installed, but the settings are all the defaults.
- SMB Encrypt is set to "Auto"
- SMB Signing is disabled.
- Min protocol is SMB 1
- Max protocol is SMB 3.1.1
All shares have SMB Transport Encryption set to "Enabled".
- SandsharkDec 12, 2024Sensei
My settings are the same as yours. I'm only guessing here, but I hope the OP does try installing SMB Plus. If that doesn't fix it, then it's something more than just 24H2, though that something more may be related to 24H2 (like a companion Plex update).
