t1addy
Dec 06, 2024Aspirant
Win11 24H2 and ReadyNAS
What did Microsoft do this time...? I allowed my Win11 Plex server to update to 24H2 today, and now it can't get to my ReadyNAS104. Firmware 6.10.10. I can get to it just fine with my desktop Win11...
saudade
Dec 13, 2024Apprentice
I spooled up a pair of VMs with 24H2. One was a fresh install. One, an "upgrade" from 23H2. Neither one could connect to my Duo V1 nor my WD EX4. SMB Plus isn't an option on either one. Note the 23H2 could prior to the upgrade.
Disabling the SMB Client signing requirement and disabling the guest fallback protection seems to have done the trick.
I know this is not "optimal" but both NAS's exist only on my local network with no external access. The only "solution" according to MS is: "Replace your NAS if you cannot upgrade your NAS software to support signing and credentials"
The MS note:
Haven't gotten the prompt yet to upgrade my "real" 23H2.
Dec 13, 2024Guru - Experienced User
Microsoft began deprecating SMB 1 back in 2014, and there were steps needed to get it to work with Windows 10 and 11 before - so not a big surprise.
It is good to get the method to keep it working with 24H2 though.
FTP and NFS should both still work (though NFS requires Windows Professional or a third party software stack).
- saudadeDec 13, 2024Apprentice
You're right on. I had to add SMB1 on the fresh install. It was already installed on my "update" install. Fortunately, MS still "supports" it.
