TVJuniorTD
Feb 05, 2020Aspirant
Windows 10 and SMB 2 2EE51BRY00128
Our IT department does not want to enable SMB 1 in Windows 10. I went through the process of installing "Enable Root SSH Access" and CLI min protocol to SMBV2. This did not work. Any other ideas?
Sandshark
Feb 05, 2020Sensei
Please be more specific as to how you enabled min protocol of SMBv2 so we can verify it was done correctly.
Would your IT group be OK with upgrading the NAS to OS6, even though you lose Netgear support? With OS6, you get SMBv3, and a lot more security enhancements associated with a more up-to-date Linux core. You also gain the ability to move the drives from the Ultra to a newer NAS without jumping through hoops if/when the time comes your Ultra finally quits.
- TVJuniorTDFeb 06, 2020Aspirant
Per (https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/SMB1/m-p/1305130#M169712)...I added "min protocol = SMB2" to the global section of ./etc/samba/smb.conf.
- StephenBFeb 06, 2020Guru - Experienced User
Did you also set max protocol = SMB2
Did you restart samba after you did this?
I do not recall if I did...I'm following up this after a few months. I do recall rebooting the ReadySAN. Is there an documentation on the steps or are these the two items I might have overlooked?
- SandsharkFeb 06, 2020Sensei
TVJuniorTD wrote:Per (https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/SMB1/m-p/1305130#M169712)...I added "min protocol = SMB2" to the global section of ./etc/samba/smb.conf.
That may not remain after a re-boot or any change to SMB shares. A better place for it is in the Global section of /etc/frontview/samba/addons/addons.conf. Create one if it doesn't already exist.
