blkgato
Nov 04, 2015Aspirant
X-Raid or Flex
I have two drives in my system and would like to have them show as two drives and not as one or mirror. This way if I have 4 - 4GB Drives I can have each one set up for different data. Thank you
Vedetta_Lumbard
Nov 04, 2015Star
Hi there,
for this set up you need to destroy the volume, disable xraid and recreate a new volume in flex-raid. Then you can decide how many disk you want in the volume.
My raccomandations is to have the nas using the default value to prevent data lost. Disc have moving parts and subject to waer.
Regards
needhelp
- cpu8088Nov 04, 2015Virtuoso
"""My raccomandations is to have the nas using the default value to prevent data lost. Disc have moving parts and subject to waer."""
raid is for redundancy. not a proper backup.
- Vedetta_LumbardNov 18, 2015Star
Yes that is right, infact the default value of XRAID enabled is there to prevent uncorrected volume creations and give yo a peace of mind out of the box. From the name you can gather the key ReadyNAS... which mean put it in the network and if you are not so savvy you can use it straignt out of the box. So if you are in Flex raid and use all the disk in R0 you are risking your data. I never said that having that setting was a backup.
Backup now a days should be second nature. It is unacceptable that after all this time of digital life people are still not backing up.
- StephenBNov 18, 2015Guru - Experienced User
I agree, but unfortunately lots of people in the forum don't have backups.
Usually they claim its too expensive. Obviously it does cost some, but at ~$135 for a 5 TB USB drive (today's amazon US pricing), I don't find that argument convincing.
The alternative is to ultimately pay a data recovery service, which is much more expensive (and might not be successful).
- blkgatoNov 04, 2015Aspirant
Thank you for the reply. I am in Flex-Raid but it won't allow me to format or create a new volume. Am I doing something wrong?
- mdgm-ntgrNov 04, 2015NETGEAR Employee Retired
You would need to backup your data and destroy the existing volume before you can create new volumes.
To create a new volume you would follow the steps in this article: http://kb.netgear.com/app/answers/detail/a_id/23131/~/how-do-i-create-a-volume-on-my-readynas-os-6-storage-system%3F
