xtrips1
Jan 26, 2020Aspirant
X-RAID2
Hello, I want to transfer all my data to another kind of NAS, but I also need the drives from which I am transferring data on the new NAS. Is there a way to gradually, while the transfer progresses...
Jan 26, 2020Guru - Experienced User
Is there a way to gradually, while the transfer progresses, move drives out of the Readynas into the new NAS?
No easy way. If you remove one disk, you lose RAID protection - not ideal, but you can do it. But when you remove the second disk, you lose all your data.
If you are very skilled with linux, software RAID, and the ext file system then it is possible to move enough data off the NAS to allow the file system and RAID array to be shrunk one disk at a time. But it is risky to do it, and I wouldn't recommend attempting it w/o a backup even if you do have the skills.
- SandsharkJan 26, 2020Sensei
Besides being risky, that would be a long process. The array would need to re-sync every time you shrink it.
Since you don't seem to have a backup of your data, you may want to consider keeping the Pro6 as a backup device. In your new NAS, you could then use fewer, larger drives, leaving some slots free for future expansion.
- xtrips1Jan 26, 2020Aspirant
Good.
Can you walk me through it? (in layman's words please. I am a sysadmin on Windows servers)- SandsharkJan 27, 2020Sensei
Can't be done in layman's terms. I explain the process here: Reducing-RAID-size-removing-drives-WITHOUT-DATA-LOSS-is-possible
- StephenBJan 27, 2020Guru - Experienced User
Note his explanation assumes OS 6. If you are running the usual 4.2.x firmware on your Pro-6, the details would be a bit different.
