waynerp
Dec 30, 2015Aspirant
XRaid and Storage Size ??
Hi All. I am new to ReadyNAS and have moved from a HP Microserver running WHS2011 I have added 4 1TB HD's and am now waiting for an enternity for it to 'resync', something i am not liking about thi...
waynerp
Hi
Thanks for reply
The 4 disks were the ones i previuosly used in my old NAS. I did a quick format of all the disks in windows and inserted 2 disks first, the the other 2 1 by 1.
JennC
Dec 30, 2015NETGEAR Employee Retired
Hello waynerp.
If that is the case then this means the disks do not have files anymore.
If it is taking too long which I think it is because it seems it is doing it with one disk at a time, try doing the factory reset from the boot menu while the disks are inserted. Doing this will allow the NAS to format all the disks and install the OS to the disks.
