aks-2's avatar
aks-2
Apprentice
Aug 16, 2023
XRAID2 calculator
We previously had access to an XRAID calculator: http://rdconfigurator.netgear.com/raid/index.html
I know the ReadyNAS products are "EOL", but such resources are still useful for those of us with units that are working absolutely fine.
I found this knowledge base article, which describes the principles of RAID, but not how varied disk capacities contribute to the final XRAID capacity.
Is there a similar calculator, or perhaps, Netger might consider restoring the old one just for reference?
I did find this thread (from 2011), which I assume remains valid to do it manually:
Spoiler
If you have single redundancy, you remove one of the largest drives. So in the case 4x1.5TB drives and 2x3TB drives, it is 4x1.5x.93=5.6TB and 1x3TBx.93=2.8TB which equals 8.4TB. If you were 3 and 3, it would be 3x1.5TBx.93=4.2TB plus 2x3TBx.93=5.6TB for a total of 9.8TB. In the case of Dual redundancy you must have 4 of the larger drives for the second layer to come in, so in the either 4x1.5TB and 2x3TB or 3 and 3 you would have 4x1.5TBx.93=5.6TB.
  • StephenB's avatar
    If you don't want to waste disk space, then with single redundancy you need to make sure the two largest disks are always the same size.  For dual redundancy, you need to make sure the four largest disks are the same size.
    If you follow these rules and start from a factory default, the rules for XRAID are easy to state:
    • Single redundancy - "sum the disks and subtract the largest"
    • Dual redundancy - "sum the disks and subtract the largest two"
    The old X-RAID calculator never handled expansion, and often that created confusion when the volume size was smaller than expected after expansion..
    If you want to avoid wasting space when expanding, then it is alway safe to
    • Add new disks that are at least as large as the largest already in the NAS
    • Single redundancy: make sure the largest two disks are the same size
    • Dual redundancy: make sure the largest four disks are the same size
    If you know the details of your system's RAID groups, there are other sometimes other options - but it is best to address them case by case.  The formulas would be unwieldy, and they would depend on the expansion history of your volume.
    • aks-2's avatar
      aks-2
      Apprentice
      I'll actually wipe the current volume - to get rid of ReadyCloud, and I want to reuse two 8TB disks in another NAS.
      I will rebuild my RN214 with 2x4TB and 2x6TB, just wanted to understand what capacity that would offer.
      I think I'll get:
      • 4TB + 4TB + 6TB for data
      • 6TB for redundancy
      • 0TB unused
      • Therefore 14TB (in HD capacity terms), and 12.7TB  of usable storage in real terms.
      • StephenB's avatar
        14 TB, or 12.7 TiB.  Both are "real", just different units for the same storage.
        ReadyNAS system report TiB but use TB as the label.
        This is the correct capacity.  Although if you are thinking that the 6 TB redundancy is all on one disk, then that is incorrect.  The parity blocks are distributed across all the disks.  If you put all the parity blocks on one disk, then the write speed of that disk becomes a performance bottleneck.  Plus distributing the parity blocks evens out the load on the disks in the volume.
  • Try web archive for the calculator.  It still works in 2025.
  • While it's unfortunate that the XRAID calculator is no longer available, resources like these remain valuable for users with functioning ReadyNAS units. Just like how tools such as the ACFT Calculator help users accurately assess fitness scores, having access to reliable RAID capacity tools makes managing older hardware much easier. Hopefully, Netgear consider restoring the original calculator for reference purposes.
  • archive.org has a history of attacks that temporarily disable it.  From the response I'm getting, I suspect that's the issue again, and it will be restored in due time.
ProSupport for Business
