p5taylor
Apr 29, 2021Tutor
Your ClamAV installation is OUTDATED!
Dear Netgear admin / fellow Netgear users My readynas has now for the last year been saying that the clamav is outdated (version: 0.100.2 should be : 0.103.2) and so it doesnt seem to want to automa...
- May 06, 2021
p5taylor wrote:
so trying to log in to do a soft re-start it appears that a different password has been set (not by me)
FWIW, 6.10.5 is now released. It seems unlikely that it would reset the admin password (esp. a couple of days after the update).
But you can do a clean shutdown by pressing the power button twice. See page 35 here: https://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
Then power up the system and see if your old admin password works. If it doesn't then try the default password (which is password)
If those steps fail, you can also do an OS reinstall from the boot menu. Instructions are on page 37 of the manual I linked in above.
The OS reinstall will
- reset the admin password back to password
- reset the network configuration to use DHCP
- turn off volume quota (which can be re-enabled via the volume settings wheel).
p5taylor
May 04, 2021Tutor
Hi John
Sorry for not getting back to you sooner, the current version of my firmware is 6.10.2.
I dont really like being a guinea pig for beta version of software had some bad experience in the past, i normally like to only have long term support version but was forced to go with stable version for plex to work properly, I would install it, if it was stable.
Regards
Paul
p5taylor
May 06, 2021Tutor
Hi John
So i finally decided to buckle and installed the beta version everything seemed ok for a day or two then later i am unable to access any of my drives via my pc, so trying to log in to do a soft re-start it appears that a different password has been sewt (not by me) tried this new password (@newdig) no joy in getting in, so gone for a forgot password and reset password this isnt working either, so great now completely locked out, should of stuck with my intitial beliefs.
Regards Paul
- StephenBMay 06, 2021Guru - Experienced User
- p5taylorMay 06, 2021TutorHi Stephen, that was a bit wierd, but a bit of perseverance I eventually managed to get in with password, done a soft reboot all seems back to normal now, I do have plex on there and also uploaded a couple of things to the server last night so I will monitor and keep an eye on it.
Good news is it looks like my virus definitions are now up to date.
Thanks for your help.
- Apr 29, 2021Retired_Member
