skumsenumse
Aug 07, 2012Aspirant
a little help with bit torrent (im a newbie)
how do i mke a shortcut to the program so i dont have to go in to setup page and please tell me some nice to know things
JarnoG
Aug 08, 2012Guide
That depends on which bittorrent client you are using. If you are using the old bittorent client that used to be included in Riadiator, then I've got no idea how to go to it directly. (I know you can, I just haven't used it for a very long time)
If you are using Transmission, you can access it by going to
http://IP.of.nas:8181/Transmission
where 8181 is the rpc-port set in Transmission (i think it's the default port, but I might have changed it for myself).
You can also use a program like Transmission Remote dotnet or Transmission Remote GUI to manage your downloads. These are programs you have to install on your computer and can be used to connect to Transmission on your NAS.
